Caliper racing
Publié: Lun 27 Fév 2012, 7:59 pm
par JoelPatel
J'voudrais savoir quel caliper vous prenez chez wilwood pour fiter avec des brackets custom sur les gt ???
Et quel vehicule ont les meme applications de freins que les swift gt 89-94?
:help:
Re: Caliper racing
Publié: Lun 27 Fév 2012, 11:01 pm
par Suzimaniac
Have Fun :D
http://teamswift.net/viewtopic.php?f=10&t=40419&hilit=brake
suzimaniac a écrit:Nissan SE-R Spec-V 2006 oem big brake Brembo kit rotors
rear disc
The Nissan rotor is heighter than the Swift rotor, but it fit the rear hub without any rubbing
Swift OE disc diameter
Nissan brembo disc diameter
Front disc
Same height
Overall view :twisted: :twisted:
I will use aftermarket caliper
Wilwood Dynapro 4 pot for front
Wilwood Dynapro 2 pot for rear
I have not received the caliper yet but I wish they will arrived during next week
There is some picture of the front rotor fitment into my 16inch wheel..
The overall radius of the kit is 6''7/8, that means that it will remain 1/8'' between the caliper and the inner wheel.
OR
http://www.redlinegti.com/forum/viewtopic.php?f=4&t=35551
Suzimaniac a écrit:There are some spec that you need to know before searching any part that may fit GTi hub.
- car - year -rotor diameter (mm) - hub diameter(mm) - rotor hat height(mm)- boltpattern
- Suzuki Swift GT - 1989 to 1994 - 250mm - 60,1mm - 50mm- 4x114,3mm
And there are the spec of other car
- Honda Accord 4 cyl - 1990 to 2002 - 259,8mm - 64,10mm - 47mm
- Acura CL 2,3l - 1998 to 1999 - 259,8mm - 64,15mm - 47mm
- Honda Prelude Si - 1992 to 1996 - 262mm - 64,1mm - 47,1mm
- Acura Legend - 1986 - 262mm - ? - 51,2mm
11inchs rotor (you need a custom bracket if you want those rotor to fit the caliper)
- Honda Prelude Vtech - 1992 to 1996 - 282mm - 64,1mm - 47,1mm
- Nissan Altima - 1993 to 2001 - 282mm - 66,1mm - 49,2mm
- Acura Legend coupé - 1987 - 282mm- ? - 51,2mm
After that I think that you can start your search
There is a link to download the wilwood catalog: http://www.4shared.com/file/61890045/c4 ... talog.html
Honda caliper are direct bolt-on on GTI hub
so we can use the bracket(250-8642) that come in the 11'' honda kit(140-8695)
PDF;http://www.4shared.com/file/61890589/676f901d/140-8695.html
or the bracket (250-6289) that come with the 12,19'' honda kit(140-6163)
PDF;http://www.4shared.com/file/61890047/2aa930fd/140-6163.html
2002 MITSUBISHI LANCER with 4x114,3mm of bolt pattern have front rotor height of 47mm so we can use the Hat(170-6996) from the wilwood kit(140-7015) PDF;http://www.4shared.com/file/61890449/ca18b526/140-7015.html
Note: if you use the lancer hat, that have a bolt circle of 8x7,00'' you will have to use 12,19'' rotor(160-5843) because 11'' rotor(160-5840) have a bolt circle of 6x6,25''. If you want to use 11'' rotor, you need custom made hat or use one piece rotor from an other car that came with 11'' from OEM.
Utilise l'onglet recherche et fait une recherche avec mon nom de forum.... tu va trouver pas mal de stock
Re: Caliper racing
Publié: Mar 28 Fév 2012, 1:34 am
par JoelPatel
j'peu pas trouver aussi precis MERCI!
